span8
span4
span8
span4
This article is part 9 of a tutorial to help you get started with FME Cloud. We will cover FME Cloud notifications. This tutorial needs to be followed in order. Please complete Part 1: Sign Up and Part 2: Launch Instance before continuing with this article.
1) Login to FME Cloud
Login to FME Cloud here if you have not already done so.
2) Explore notifications
Click on Notifications on the left sidebar of your dashboard. You will notice you have two options here: Notification Groups and Notification Services.
Two pages under Notifications: Notification Groups and Notification Services
Click on Notification Services. A number of notifications are set up by default: the emails of FME Cloud account users.
Default notifications for every user
3) Create a notification service
Click on the Create Notification Service button. You have several options: email, PagerDuty, Slack, and Webhook.
Notification Service options
Each notification service has its own configuration page. Some fields have a tooltip or links with more information.
For example, you could set up a Slack notification service. Enter the name of the notification service, e.g. “FME Cloud to Slack.”
New Slack service form
You can set these up yourself within your Slack workspace webhook configuration page. Fill in which existing channel to post to (try a private channel for testing first):
Setting up a Slack workspace incoming webhook configuration
Then copy the Webhook URL to use in FME Cloud.
Pasting the Slack webhook URL into the FME Cloud New Slack service form
If you set this up and then click the Save button, you will see it added to the list of notification services. From here you can click the Edit button on the right to change the configuration.
A new Slack notification service is added
4) Test your notification service
Select your new notification service by checking the box next to its name.
Click the Test Service button.
You should receive a green alert box saying a test notification was sent:
Test notification alert box
If you set up a Slack notification as per the instructions above, it should look something like this in Slack:
Slack notification example
5) Explore notification groups
Click on Notifications > Notification Groups.
By default, you will have no groups. These groups can bring together multiple notification services. If you wish to, click the Learn more button here to read the FME Cloud documentation related to notification groups.
Click Create Notification Group to create a new group.
Create Notification Group button
Fill in a name for your notification group.
You will see all your notification services listed below. You can choose which services are part of the group. Click Save.
New notification group
Now you will see these notification services are all part of one group.
We will cover how to use these notification groups in the next article, where we will cover FME Cloud alerts:
Getting Started with FME Cloud: Account Security
Getting Started with FME Cloud: Launch Instance
Getting Started with FME Cloud: Instance Actions
Getting Started with FME Cloud: Instance Resizing
Getting Started with FME Cloud: Backup Snapshots
Getting Started with FME Cloud: Schedules
Getting Started with FME Cloud: Alerts
Getting Started with FME Cloud: Events
© 2019 Safe Software Inc | Legal
